Thanks, brother! Yeah, I've watched that one a bunch and I'm sure I'll watch it again more than once. Fortunately, I won't be welding anything much less than 20 ga aluminum so my current skill set is pretty dialed. I'm actually way better with TIG on aluminum than steel for now as I've not hardly spent more than maybe 2 hours messing with steel and probably more than 65-70+ hrs on Al so, I really like working with aluminum though. I'm doing my entire interior in it with a carpeted overlay and accent panels built into or on top of the aluminum panels with some black heavy vinyl upholstery I picked up long ago. Should be nice when I'm done, just need to find a cheap source here in Sac for sheet aluminum that I can pick up without donating my annual salary..maybe helpful
Quite fitting, No?!?I totally understand the naming of your car now.
now that I can finally do the work correctly, I have my work cut out for me for sure! I already know someone previous to me had just laid a fresh rear driver's side floor pan over the old rusted out one and tacked it in everywhere so I need to replace it but I have complete new L/R pans front to rear. Gonna cut them up for just the parts I really need to replace and I'll repair the rest before I get to welding. I have my subframe connectors to weld in and the 8-point (soon to be 10 point) to build and install so I have a bit of welding soon... and cutting... and grinding... and more grinding... and more welding... LOL YAY! I get to finally work on this beast though!!! Happy guy!Unbelievable!!!!!!!!
Yeah, I will likely wish that too however, for my purposes, I'm not totally dead set on perfection in the looks department down under (smooth criminals.. LOL), and I have some fabrication to do too as the PO MethHead did a real number on the tunnel...I also replaced my L/R floor panels only toe board needed replaced both sides but installed both whole front to rear pieces. I wish I replaced the whole floor with the one piece. I think it just looks better,nicer when looking from underneath of the car.
I think it's actually the old tunnel, just totally FUBAR from the hacking. They welded a shifter "hump" on it (consisting of a box welded with what appears to be flux core toothpaste) to close up the mess as it was likely an original auto car. Just a total METHIs that an oil drum? LOL
At least not "Meth-Enhanced"...Some people shouldn't try to do fab/bodywork.😱
I love this line! What a great way to describe the feeling of rowing gears in a powerful car. Love the good attitude and humor sprinkled throughout this thread. "Methtrap" is a perfect name considering some of the work you've unearthed. I'll be reading along!I could not keep the tires from spinning no matter what I did. It was like I was getting a mainline shot of epinephrine every time I changed gears. IT WAS AWESOME!!!
I bet they knew each other... Thinking maybe they had a common friend, Heisenberg?!?The PO I got my car from used what appears to be a claw hammer for the shifter opening. Also when I had it on the rotisserie I found some hieroglyphics on the leaf spring that said "this car is a piece of S" and "I hate this F'n car" written in pencil. A little methy but the car had not really been molested that bad.
