I've got a 71 Nova that I upgraded to power brakes using a stock component kit from Pirate Jack. I was happy with the performance until the passenger side front caliper started sticking closed, chewing through brake pads and causing a dangerous pull. I checked all the obvious possibilities like a flexing caliper or a kinked line but didn't find any issues so I assumed it was a bad caliper and had Pirate Jacks replace it. It started working ok and I figured the issue was over but now its started again and I feel bad for guilting PJ to replace the caliper since this isn't the problem.
The caliper seems to only stick when its hot, like hot outside or after its been running a while. Once cooled it will unstick usually. This has to be something to do with the proportioner valve right? I did have to remove a loop where the stock brake line pigtailed to get it to reach the new proportioner but I *think* that was from the back brakes line, honestly can't remember though. Could this be it?
Thanks for any help I just want this gremlin killed.
