I have a 63 with fender well headers and installed a front disc brake kit, i relocated the per portion valve in front of the shock tower because it doesent fit under the master and i also relocated both t blocks to get them away from the headers, but the rear line on the master is 5/8 of an inch away from the header and there is no getting around it, is that to close? Will the heat boil the dot 4 brake fluid or is it fine, i do have jet hot coated headers! I was also thinking of running som fire sleeve thats good to 500degrees indirect heat on the brake line, what do you guys think?
