Time for the experts! While searching for a vacuum leak I pulled off the plastic valve that goes into the power brake booster.The other end of the vacuum hose is attached to a tee that goes to the back of the carb and then to the pcv valve.When I pulled it off the idle went up and smoothed out.If I put my finger over the end of the plastic valve the idle gets rough and slows down.Here's my question.....Should the brake booster have a separate vacuum line instead of also going to the pcv valve?Is that screwing up the vacuum signal for the pcv valve?Thanks…..and you guys have answered a lot for me!
