Found a great deal on a 11 inch brake booster master cylinder and prop kit. Brand new in the box for 100 bucks. Its made for a 1970 camaro or a body cars. Will this work for my 64 nova?
Probably not, the a-body boosters are larger diameter and mount at a wierd angle.
brake booster help needed
66 chevy II wagon with new TCI front end just installed with front disc brakes. old booster and brake lines are all gone. looking for correct booster and master cylinder to buy as well as a low cost source for pre bent brake lines. if anyone has suggestions. Classic industries looks good but too many booster/master cylinders to choose from. Anyone have a new master cylinder installed and working that they would suggest a good source? this is going to be a driver. small block and auto tranny.
Banned
a 9" booster is the largest that will fit... and with that you'll barely have room between SHORT valve covers and the booster.
tall valve covers won't clear...
for a ChevyII you'll also want the 3 bolt style booster. no 4 bolt, it'd be incorrect. an 8" dual diaphragm or a 9" booster would be what you'd want.
contact these guys: http://www.getdiscbrakes.com/
thanks for the reply, and the reminder of the 3 bolt requirement. Classic industires show a 7,8,9 and 11 inch booster. i will check out the get disc brake guys.
