Nice video. I like the lil vids guys make for simple operations. The grease as said is for an air seal, I like a really tight rubber hose, works just as well. One thing though, I dont like that black, dirty fluid in the container. You may be sucking that up into the wheel cylinder. I like a perfectly clean container and brand new fluid if you use that method. I use a vacuum anymore when bleeding. But nice vid. JR
I thought of making something similar to the one in the video but the hose would probably have to be different cause I think the bleeder screw on the disc are larger than the screws for the drums on the rear.
· Premium Member
Just wondering, do you pump the pedal till no bubbles when doing a one man bleed? Looks like you would pull the bubbles back and forth at each pump.
Does the one push get the bubbles in the jar so they don't stay in the tube.
JR:eek:
The method works like this. One man setup. You submerge the tube from your open bleeder screw into a CLEAN jar of NEW brake fluid. So you have the bleeder open and pump the pedal. It pushes out the air and pulls in fluid from the jar instead of air if you didnt have the jar. Kinda a back and forth thing. Thats why I didnt like the black fluid he was using, do you want that in your wheel cylinder?? JR
