Has anyone installed speed bleeders, or replaced the stock bleeders on their CPP brake kit? I called CPP and asked the application of their zero-offset brake cylinder and was told "I'm pretty sure they're for a 79-82 S-10". Result: one ruined Russell speed bleeder. The threads are correct, but the tip which seats in the cylinder is barely too large (in diameter) on the speed bleeder. When I tightened it, and felt resistance, I assumed it was the thread sealer, but when I backed it out, the bleed hole had been crushed almost closed. Bottom line is, I wonder if it's possible to put speed bleeders in these brake cylinders. If anyone has done it, let me know.
