1 - 3 of 3 Posts
Sry the guy put his hand in the way as soon as i took the pic. Lol
There's a guy down the street that says he'll sell me this borg warner s10 nwc t5 for $250 (and that if there's anything wrong with it i can return it).
My first question is, is $250 a good price? (Its $1200 brand new)
The gear ratios are either
1st: 3.76:1 2nd: 2.18:1 3rd: 1.41:1 4th: 1.00:1 5th: 0.72:1
or
1st: 4.03:1 2nd: 2.37:1 3rd: 1.49:1 4th: 1.00:1 5th: 0.86:1
My second is, what would i have to do to install it in my 69 nova with a 350 sbc?
I already know that this trans isnt that strong but i dont plan on beatin on it and i hate the t350 trans in my car now. It's basically a replacement until i can afford a tko.
Thnx
Post the ID # from the trans. It will be 1352-xxx. The trans has a few problems for using behind a v8. 1. The input shaft may be too long. You can use it if you cut off about 1/4" from the nose. 2. The input shaft spline count may be funky. It will take a special disc, along with a Camaro pressure plate and flywheel. 3. It will take a different driveshaft yoke than your T350. 4. You're right - it isn't very strong. But I made one live behind a stout 350 in an '83 Z28 for a good while. Just don't go drag racing. 5. I think it's too high priced. I'd pay maybe $100-$150 for it. Basically, use it if you have to, but I'd hold out for at least a V8 Camaro unit. Oh, and the shifter is in a different location than the Camaro transmission and also the TKO, I think. So you'll have to cut 2 holes in your floor if you swap it out.
Part #1351097901
Wow that sounds like way too much work for my skill level and cutting the floor for this temperary trans then cutting it again for a tko just made my mind up. I guess ill just try and find a cheap t10 for now. I dont really have to do to much mods for that right?
1 - 3 of 3 Posts
