Here's another example......a popular
[email protected]%& M#!*(#? II front steer rack suspension...
inner lower a-arm pivots 22 1/4 " c/c, rack pivots 24 1/2".
On a front steer rack, the Ackerman angle forces the outer tie rod to be
farther out than the lower ball joint, so the rack pivots will almost allways
wider than the lower a-arm pivots.
If the tie rod & lower a-arm are close to the same lenght, they will move in
about the same arcs,& have about the same rate of change...this will minimize bump steer.
Example....aftermarket front end made in Northern California has a tie rod length of 13.5" & a lower A-arm length of 13 11/16"...with practically zero bumpsteer.
What rack were you looking at ?
