BBC vs. SBC
  • BBC
    Votes: 216 33.1%
  • SBC
    Votes: 387 59.3%
  • Straight 6
    Votes: 17 2.6%
  • Don't care as long as I can spin them.
    Votes: 33 5.1%
  • Total voters
    653
201 - 220 of 235 Posts
Big Block definitely! :yes:
Not a Nova, but here's the BBC combo in my 71 Chevelle. I have not had it on a dyno since I had the heads ported and swapped intakes, but it should be making close to 700 horsepower. :thumbsup:
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
Big and Bigger
I am on my second Big Block in my '69 Nova.
However, a hot small block is really plenty fast, a lot easier to squeeze into the car, and parts that fit are everywhere.
I have had a good 350 under wraps for far too long. Time to wake it up.
Bbc
i like big blocks with nitrous. I have a shafiroff 582 in a 69 vette and a 468 with a 150 shot in my 72 nova. The fastest cheapest way is 5.3 with a turbo. Check out Drag coverage forum. A guy has 5.3 with force induction turbo i think in a trans am running 5.88 in the eigth. Around 3 grand into it.
Big blocks are so much more fun. Im upgrading from my 396 BBC to a built and balanced 454. Saving up for a blower this winter so hopefully next race season ill be running 10's or faster. :devil::yes:
you plan to run that car on the streets much? considering similair power levels just dont know if its "too much for the street" :turn:
Big block is the only way to go. My mild setup (496) is putting out 595 ft-lbs of torque and 565hp at the flywheel. Will be going back in my 72 nova daily driver. :D
did you ever get the motor in and daily drive? considering similar build maybe some more power tho...ever wish you had more?? sweeeet build!:eek:
do you drive that 582 on the streets ever? considering similar cubes for mine but dont wana be overkill on the streets!
sick ride!
496
10.5 scr
you ever drive your chevelle on the streets how are the street manners?
I have an aluminum LS 5.3 LM4. I just tore it down completely and flex honed the cylinders. It will be making its way down to the machine shop soon. I will be building it for a twin turbo setup.
I had a 396 in my '71 Nova and now have a '63 with a small block. So far, I like the '63 better. It has the TCI 4 link and CPP minisubrame. Handles nice and the car is light compared to my '71.
I'm having a blast with the small junkyard LS stuff.
2010 5.3, DOD delete and 229/235 cam, 3800 stall TH350, ebay headers, and 3.73s in a 10 bolt. [email protected] Shifting at 7000 and drive it anywhere.
It runs as hard as a Dart head 383 I had years ago, although admittedly I've learned a lot about getting a car down the track since then.
i see alot of people going from a 355 to a 454 and loving the difference in power. but i can tell you i would run a well built SBC before a BBC any day of the week. you can get Big Block power in a Small Block package! its proven every day! <img src="http://www.stevesnovasite.com/images/yes.gif" border="0" alt="" title="Yes" class="inlineimg" />
That small block can't match the torque though. And a small block is going to need expensive aftermarket heads to do what a big block can do with factory castings.
Knocked back a 434 SB only to build a 489 BB... Hopefully one day in this lifetime when it's done I'll see what the fuss is all about...
No replacement for displacement, luckily the LS series is a stop gap. Going with a mild 5.3 and stock front. Have a the rad and CBR mid tubes. Pulling my SBC this October and installing the 5.3 fall of 2020.
