I have a 78 Nova and I am swapping in a 454 / th350 combo.
Anything unique to this swap compared to putting a big block in a 70 Nova?
Someone mentioned the front subframe is more like a 2nd gen Camaro than a 3rd Gen Nova.
Any help is much appreciated.
Yes, I believe a 4th gen Nova subframe is very similar to a 2nd gen Camaro. With that in mind, I would think you should be able to use BBC frame mounts from a early BBC Camaro to get the offset correct, if it is even necessary. There are others on the site that have put a BBC in a 4th gen that will be able to give you much better insight.
Randy (If I'm not helping, consider this a bump!);)
The 4th gen sub frames have the 1" offset built in. No special mounts will be needed to drop in a BB. You should notice on the trans crossmsmber the mount is offset to the pass side. Here are some photos I posted in another thread.
