ok . . I'd first say : run you a 'Hot wire' , straight to your + side of u'r coil to the pos post . Then start
your engine. That will tell you ALL of your Engine parts are still working : alt ; coil ; starter ; ignition systems
are still good.
Then, go for checking your under hood wires. I'd also check your Fuse Box , for any fuses being bad.
It could be something very simple - check those areas 1st.
Plus, until You find something of issue - - - I would keep your battery disconnected, when
not trouble shooting.
and , keep us posted .
jim
are still good.
jim
