I'm having a little problem with my 70 Nova SS starting. It appears that fuel is being sucked back into the tank after the motor is turned off. If the car sits around too long then I really have to crank / pump it a long time to start. No leaks visible. SMI stage II Q-Jet. It has the stock style return line and all the tank vents hooked up to the carb and charcoal canister OEM style. I was thinking a fuel line check valve would help. Anyone know of a reasonably priced valve for 3/8" rubber fuel line? Looking at a check valve for a diesel engine. They are around $10.00. Thanks, Jack
