Hi all,
I recently received my 4 link backhalf kit from Checkered Racing. http://checkeredracing.com/4LinkBackHalf.html
I have been reviewing these writeups on backhalving Chevy Novas:
http://www.hotrodder.com/projects/backhalf/backhalf.html
http://autoweldchassis.com/Instruct.ivnu
I was a a little over-ambitious when I removed the rear subframe assembly a few years back. I just removed the entire rear subframe/suspension assembly w/o taking measurements and/or plotting where the axle centerline was in the car's stock position.
The two links above, both use different methods to arrive at the same end result. I understand the general procedure of backhalving, you want to keep the axle, the subframe, and the car itself all square, and level to one another...
But what I don't understand is what to do now that I have no stock subframe to go off of for axle position. I would think that this could just be ''eye-balled'' in the wheel well openings, front to back, and side to side..
EDIT:Also, should the front crossmember of the new subframe go in about the same position as the stock counterpart???
I have tried to make this post as coherent and logical as possible, however if I haven't done a good enough job, I will gladly attempt to clarify.
TIA
TIA
