The shifter will come with the necessary micro switches you just tap into your existing neutral/back up switch wires or plug.
No harnesses that I'm aware of. Easiest place to tie into the neutral safety circuit is at the steering column. Two big purple wires, and you can use spade connectors to plug into it. Green wires for back up lights are close too.
