Ford 9", brand new axles that already have the bearing on them, only everything that i have read says the O ring supposed to go toward the axle flange and not the splines. Well these the o ring is toward the spline. Ok to run???
· Premium Member
It's been a while since I've done one.
I think the O-ring seals the oil. If it's towards the splines then it will inhibit the bearing lubrication. I'd call one of the 9" axles specialists tech line like Currie to be sure.
· Moderator
1963 wagon
depending on who made the bearings I've seen them designed both ways. You should still be running an inner seal ( 51098 ) for large bearing 9".
Miles
