OK so I went to a autoX on sunday and found some things I didn't like about the car.
Set up I have on now.
CCP 4 wheel disk brake kit with performance friction carbon metalic front brake pads, no fad worked good
Hotchkis suspension - with out rear sway bar.
Koni red shocks
CCP front control arms
poly sub frame bushings
When pushing the car hard the front pushes bad, after like 3/4 of the way to full lock the car allway starts to push, no over steer.
ahh open diff not helping out too much.
front tires are 235 40 17 show tire wear all the way out on the out side tread with 39 psi ( maybe + camber ) none on inside
rear tires are 245 45 17 with 35 psi even wear
Koni red shocks
