Funny, I was just going to search for the same thing. Redoing my friends 64 post and all the new seals and run chanels are in with the exception of the quarter windows. We were thinking of screwing or riviting it in but figured the glass would hit the rivits.
HAve know input, but recently asked about seal quality and brands. What brand did are you using and how did the fit look?
On my 66 the glass runs were held in with a button type fastner that had a kinda staple effect with tangs that were bent over .I have heard where the runs can be glued in place(weather strip adheasive) when the correct cuts and dry fitted before final install .Good Luck
http://www.parts123.com/parts123/yb.dll?parta~partsort
The Link no workey ? Go to Chevy2only Part# 54020-1 .49cents
Discussion Starter · #5 ·
ack
trying to figure out how to reply.will get back.
Discussion Starter · #6 ·
glass channel
thought about using adhesive but have some doubts if it would hold.the channel i have (j.c. whitney prt#75000048, 23.99 per 5ft stick) has a pliable bottom,if using a thin headed screw, it would set down in the channel an not interfer with glass movement.
mdnt
