and I just want to say F**K it all.
You may have seen my fuel tank thread. I had a sump welded to a BRAND NEW Goodmark tank to use with an electric fuel pump. That set me back $50 which I figured was a great deal. The guy is supposed to be the best local welder and he does a lot of welding for a friend of mine. So, after weeks of careful planning ... and painting of the tank I put it in as well as an entirely new fuel system. But the stupid tank leaked. Had a tiny tiny tiny pinhole leak where the sump was welded on the passenger side of the tank. OK ... I'll take the blame for this one. I should have water checked it like was suggested. But this guy is supposed to be the best, so I didn't.
Drain out 14 gallons of fuel in my driveway and remove the fuel tank. I take the welder the tank and he repairs the weld. This time I was smart enough to water test it when I got it home. Still leaks. Same spot but much smaller leak. Now the guys sick and out of commision for a few months.
So I take the tank to the local radiator and tank shop. They say there's spider cracks in the tank. Blame it on the thinner gauge aftermarket tank. Whatever ... just make it right I tell them. So $125 later they grind down the welds and weld in a plate that runs the length of the sump. They put air in it to test it they tell me. Great! I pick it up 40 minutes ago. Run it home, fill it with water and the F**KING thing leaks in 4 places now. All along the repair they made.
I just hope the tank can even be used now. What if the thing has been worked on so much that it's no good? I don't know much about metalurgy, I'm just really frustrated right now and needed to vent.
It's experiences like this that make you wonder why you even do it.
