Has anyone with a 67 used the cpp brake booster ?
How did you connect the existing rear brake circuit to the combo valve ?
CPP gives you a blue nut, is that suppose to allow you to cut off the existing nut and replace and reflare.
If I were to do that there is not enough line to get a flaring tool on it.
There does not look to be enough space to use an adapter and make a 90 degree bend to get back to the old line.
Anyone run into this issue.
I had flex lines made but the 90 and the adapter will not fit.
