1 - 2 of 2 Posts
Would anyone out there know how to remove the ignition lock cylinder from a 77 nova?...the key no longer works....and if I can get out the whole cylinder a new one online is only about $15...but how to get it out???..some say the key has to be working and you have to rotate it to get it out...but there has to be another way right??...for all those that lost the key or with broken ignition cylinders like me there must be a way..right??...well..if anyone knows..PLEASE LET ME KNOW....THANKS!!!
I think if you remove the signal switch,you will see a stamp in the housing at the end of your switch.You break that with a small screwdriver and use something like a hacksaw blade to push down the brass clip that holds the switch in.
1 - 2 of 2 Posts
