1 - 1 of 1 Posts
most of the time you need to crank the starter for along time to get the led to turn green for it to start or be in sync:confused:. also it will be running fine and the led night will go from green to red, but the motor will keeps running.:confused: we have good single coming IN to the conversion module on the crank and cam, but coming OUT the crank is good and the cam has a long delay under engine cranking.:confused:. we had changed the cam sensor and the PCM it made no difference....:mad: thks
1 - 1 of 1 Posts
