O.K. I ran the data through Desktop dyno basic and Dyno 2000 and of course got slightly different numbers each time. Power band is in the same area though. Most likely, i'm guessing the motor's probably not going to put out as much as either of them says. If anyone can spare a minute, can you give a better estimate? i know some of the parts are not ideal but i need to re-use some of my old stuff untill my pockets fatten back up.
here's the 383(385?) set-up:
-350 block with 3.75 stroke crank and 4.040 bore
figure compression at 10.7 (might be a point or two off but that will work for now)
-Dart Iron Eagle 200cc heads (because my freebee motown 220's fell through)
64cc 2.02./1.6valves. i pulled the flow numbers from this sight:
http://users.erols.com/srweiss/tablehdc.htm
-Holley street dominator high rise dual plane intake (with 2" carb spacer)
-Holley 870cfm street avenger carb
-Comp hyd roller cam XR282HR-10 w/roller lifters
duration @050 230/236
factory lift: .510/.520
110 lobe seperation
-1.6 roller rockers (i know this changes the lift numbers)
Figure open headers with 1 5/8 primaries. I can give more details if necessary.
Dyno2000 gave peak [email protected] and 520TQ at 4000RPM
ProRacing sim(basic) gave 561HP at 6000 and 578TQ at 4000
I'd love to be making 561/578 but i figure thats probably pretty unrealistic. also, those numbers were run with 1.5 rockers instead of the 1.6 i will be using.
If anybody has a different calculation, I'd love to hear it. I only wish i could afford to put it on a real dyno when it's done.
THANKS, -Tim
110 lobe seperation
THANKS, -Tim
