1 - 10 of 10 Posts
I recently installed a mild 283 in my 64 SS. I had a CSR mini starter on it and had a problem with heat soak Saturday night. My car is runs at around 10:1 compression and 12 degrees initial timing. It starts really quickly, when the starter isn't hot.....I have cc-14 Sanderson headers and 2.5" pipes, one of which is pretty close to the starter at the bend. I also had a heat wrap on the starter but not sure if it holds more heat out or holds more heat in. I have run the Powermaster XS Torque starter in our Camaro with full length headers with great results! has anyone else had this problem or and experience with a particularly great brand of starter? I plan to buy a Powermaster XS Torque for this application and use heat wrap on the pipes from the collectors back past the bell housing. Shouldn't this work? Ideas? Comments?
Can you clock the starter to get the solenoid away from the exhaust? I ran a small starter and ran a Ford solenoid to start the engine. When I went to another brand of header, the heat was further away from the starter. I continued to use the Ford solenoid but could have rewired to the starter solenoid and not had a problem. Instead of wrapping the starter, try making a heat sheild to keep the heat away from it. The heat wrap may not be letting air get at the starter for cooling it.
I'm just heat wrapping the pipe this time but not the starter. The Poweremaster will swivel around so I can get it better this time I hope.
Vendor
Cheapest fix is a Ford soleniod.it works realy well to correct this problem.
Yeah, I just bypassed the solenoid on my mini starter and fender mounted a solenoid. My motorhome got me stuck at the gas station pump in barstow one summer coming from vegas. Had to wait 20 minutes for thinks to cool down. What a drag. JR
Kind of hard to see but its on the left hand side inner fender. Click the pic, it opens up a lil
The solution:
http://www.novaresource.org/starter.htm
While this WILL help, it's no gaurantee that it will fix your problem. I've been running a Ford solenoid since I got my car and I still deal with heat soaking (hard starting) from time to time.
+1 this is true, it really depends on how close the header is to the starter. plus a really good starter helps. and what chuck said.
1 - 10 of 10 Posts
