Hey guys,
I just installed a pair of Lake Wood Traction Bars to my 73. I also replaced the entire front end suspension at the same time. Now, my best friends father came by and said that I was dead wrong for actually using U-Bolts on the front of the Traction bars. He claims that by using U-Bolts I'm putting far too much tension on the rear. Is this accurate? I mean why would their be holes for the U-Bolts if you're not suppossed to use them? Am I wrong for using them?
Anyways, after I did these 2 jobs on my car I took it for a lil test drive. My car drove terribly. To be more precise, my steering was so unresponsive I could hardly stay between the lines, and turns were a nightmare. I automatically assumed that this poor steering response was due to a much needed front end alignment...from replacing all the front end suspension (including Tie Rods of course). However, my friends father claimed that the alignment wasn't the answer, and that the unresponsive steering was a direct result of using the U-Bolts on the Traction Bars.
What do you guys think? I'm still guessing that it's just a Front End Alignment issue. Any help with this would be much appreciated. Thanks- Mike
