I have a 64 with the antenna on the pass side cowl. What is the easiest way remove and replace the antenna? Can it be removed from the inside under the dash?
Anntena Pic
I have no kick panels on my 64 moredoor so I took you a pic of the lower part of the antenna that is behind the kick panel. Arrow points to the strap that holds the bottom.
EarlyIIs
65 2dr sedan with cowl antenna
I have the same type of antenna, cowl mount, same location. Anyone know where I can buy a new one or a good replacement. All I can find are front fender and rear quarter mount antennas. Thanks!
