1 - 3 of 3 Posts
Does the bronze half moon look’n piece in the second pic go underneath the lower metal or under the upper opening...up against the cowl? If I put it under the lower opening I have to remove the white spacer, but there is still not enough threads coming out of the cowl to screw the last piece that tightens the antena. If I put it under the upper opening it looks like I should be fine with the amount of threads exposed but I would like to install it correctly without possibly damaging anything. This is an after market from CI.
Thanks fellas
I believe it is under the upper if memory serves me correctly. It was a while ago I had mine off though. That half moon allows you to angle the top or bottom a little as necessary. If it was under the lower I think it would reduce your ability for adjustment if you know what I mean as the top passes through to layers of metal.
Thanks numbersguy. That’s what I thought and it makes sense the way you described it (y)
1 - 3 of 3 Posts
