After fixing the sloppy job the PO did with the shifter and console, I finally got carpet back in my 68 Camaro:
??? are your drain plug s in upside down, and or does it matter? Did you weld in the patches and then use seam sealer? what did you do underneath IRT the seams/ joints
I did not do the floorpans, po did a strange job of it. New pans were welded in without cutting the old ones out. They’re mig’ed around the edge and have seam sealer on top of the seam. Someday I’ll replace the whole floor, but it’s ok for now and i want to drive it a while before I tear it all apart.
Pretty sure the floor plugs are the right side up...
