Yes, it's been a while, but the project is finally making some progress. I was able to get things rearranged in the shop so I could get the Nova dug out and positioned so I can work on it.
First task is to get the front clip installed and fitted. I bought the Dynacorn fenders a few years ago and once I got them unboxed and hung, both have major issues. The right side where it meets the door is no where near the correct profile. After a week of cutting, grinding and welding, I finally got it pretty close, but I'm still not happy with it.
The left fender initially looked pretty good, but after I got the hood mounted, I discovered the entire skin is shifted up on the internal bracing about 3/8". This makes it too high in the front next to the hood, and too high where it meets the door. After looking at it, I would have to cut all the bracing loose to get it moved down where it should be, but the way the metal is wrapped around the rear at the door opening, that's not possible, at least not for my metalworking abilities.
So, I ordered two new fenders that may be here by Christmas.
I did get the bucket seat mounts fitted and welded in, but that was another advneture. I ended up using the inner mounts that straddle the driveshaft tunnel that were removed from another Nova. But I had use the outer mounts out of an aftermarket set and modify them to get them in the correct position.
I had bought two sets of bucket seats, both were out of '69 or '70 Chevelles, and I was assured they were the same as those used in Novas. Well, almost the same. The tracks are different. Chevelle tracks are an inch longer where they bolt to the seat and where they bolt to the floor. So I had to buy a set of Nova tracks, and they do bolt up to the seats, but use a different hole at the rear.
I had disassembled one set of seats, sandblasted and painted the frames, had installed new springs on one of the bases and started installing the foam and cover. But that's as far as I got. So I pulled out that base and the two seat backs, but couldn't find the other base. Tore the shop apart looking for it. Never found it. Thinking back, it may have been rusted too badly to use and I scrapped it.
I took one of the other seats apart and stripped the base down. Didn't look too bad, so I spent a couple hours blasting all the rust and crud off it. Primed it and got black satin Rustoleum on the top. I'l do the bottom tomorrow.
I also installed the springs on the second seat back, What a freaking job. Fought it for an hour and a half, but finally got it all snapped in place. Only lost a cup or so of blood working with those springs that all have sharp ends on them. Good thing I'm a good healer.
