^^X2 :yes:The running temp will be the same, the heads will just heat up faster.
They will also cool down faster, water temp should be the same with a t-stat. If your not running a t-stat you might find the temp a little warmer, because the heads will transfer heat better.
IMO
From what I have found.
I like my engine temp taken on the intake.
Al
Water temp or actual head temp?Thanks for the input. So head temp maximum would be say 220-230??:turn:
