So I was under the car checking the transmission and I noticed my body mounts look pretty bad. I'm thinking it's time to get some aluminum ones. The only problem is, the ones I found at Summit's site are only half of the necessary parts. Apparently you have to use one of the rubber ones you already have??? :confused: That seems stupid if you ask me.
Anybody know any companies that make "full" kits? I'd prefer aluminum upper and lower mounts than an aluminum upper and a rubber lower.
Matt
Matt
I did an install on a 69 Camaro with the kit from Detroit Speed and Engineering (DSE). VERY nice stuff! http://www.detroitspeed.com/
Thanks NIIN20. I checked around at their site, and they have a lot of other nice stuff that I'd like to buy as well. :D
Anyone else?
Matt
Global West would be another company that sells them. Good luck..
I think if you use the solid upper mounts, all you need on the bottom side is a large washer and accordingly shorter bolts.
The use of the lower cushion was to isolate the bolt from the subframe (with the rubber mounts).
