1 - 20 of 21 Posts
Anyone here ever heard of or had any experience with Short Turn (company name) alum. heads. By the way thanks to everyone for ansers to questions I have posted, and ones I haven't. There is a wealth of information on this site. Thanks Again
· Premium Member
be careful...most no name heads are cast in china.Go with edelbrock,trick flow or afr.bm
Discussion Starter · #5 ·
Iv'e seen the heads and the spec. sheet, manganese bronze valve guides,190cc int.runners,64cc combustion chambers,no lead compatable,straight plugs,7deg. machined valve locks,7deg. steel retainers,2:02+.100 stainless swil int.valves,1:60+.100 stainless ext. valves,1.25 single valve spring,[email protected],[email protected] 1.300,viton valve stem seals,5/16 guide plates,arp 3/16 rocker arm studs. p/n pfs190202-2a, price 850.00 (2) Could these be made by someone else and sold under the Short Turn name?
I know a guy around here that sells cylinder heads that are not a known name brand. I am wondering if they could be the same heads. I know they were 190 cc runner heads with 2.02 valves. He said they were cast from the old Pro Top-Line castings. Don't know for sure though. I helped a friend of mine put together a 350 for a mud truck with these same heads and it ran really well for stock set of heads with a solid lifter cam.
He also sold them for the same price. Had heart shaped combustion chambers also.
I have a Scatt rotating assembly in my 385 stroker, my machinist was so skeptical when it came time for balancing only to be proven wrong, every rod and piston combo with in 1/2 gram of each other:yes::yes::D
· Premium Member
There's nothing wrong with Scat parts. Been using them in SBC and VW engine forever. Just put a set of Scat rods in my BBC and I'm not worried in the least little bit, neither is my machinist.
Most of the machinists and engine builders I've dealt with and talked to actually prefer the Scat line over the Eagle and RPM stuff. Not saying there's anything wrong with the others, just that the finishing work done by Scat seems to be of a higher quality.
I've used all three in different builds and haven't had any issues.
But lets face it folks, there's a LOT more to accurately casting and machining cylinder heads than forging and machining cranks and especially rods.
· Premium Member
I'm willing to venture a guess and say the heads in question here are made by Pro-Comp Electric. And I'd be highly surprised if I'm wrong. How about some more information on them, or a web address where they can be found?
· Premium Member
:puke:proComp
For those looking for an ALL AMERICAN MADE set of aluminum cylinder heads that are genuinely designed by AMERICANS to WORK. This is hard to beat!!
http://www.profilerperformance.com/sbc-heads-176.html
Then there's the Summit Racing offerings that are cast by Brodix and Trickflow (Both KILLER castings) for under a grand as well...
:puke:proComp
Nice price. Edelbrock heads assembled are 570 each, not a bad deal. JR
1 - 20 of 21 Posts
