It would appear I am at an impass. When I bought my Nova the battery kept draining down and dying which made me think I had a short. Therefore I installed a new battery with quick disconnect on the ground terminal, but it kept happening. I had the alternator (a 1-wire) tested while in the car and even running the car was only at 12 volts so the alternator was not charging the battery. I have now replaced the alternator (another 1-wire) and the wiring from alternator to battery with new 10-gauge. However I am still only getting between 11 and 12 volts when running. What else could it be?????
Here are the new parts again:
Duralast Gold Battery
1-Wire Alternator
10-gauge wiring, Alternator to Battery Terminal
I dont know of any other parts within this system that could be failing and causing this issue
1-Wire Alternator
