If it is hooked up correctly, take it to a rebuild shop and have them fix it. It could be something really minor.Just did the test and it just stays at 10 must be bad alternator. Internally regulated.
He is probably running off the battery. I'm surprised he got it started without a jump.have auto zone test it first.
if you are getting 10 volts doesnt that mean you are running off battery power?
also, you should charge your battery![]()
They can go to 20K RPM for short periods, 18K continuous. What is your pully ratio? that is what determins the altenator speed.Yea, no warrenty left, My wife is going to take it today and see if I can get it rebuilt. Do you think that it was spinning too fast?
5"= crank 8,500 rpm is that right? I not to good at math.tnblkc230wz the links are not working. You just need to know the circumferance of your crank and alt pulleys. If the crank pulley is 12 inches in circumferenc and the alt pully is 4 inch in circumference then your ratio is 3:1 Multiply your RPM * 3 and you will have your altenator speed. you can use a tape measure to measure the circumference.
