The calipers Im using are 80 Malibu fronts. I bought a ajustable prop valve but Im not sure where to plumb it.
1) Between master and old combo valve?
2) between old combo valve and rear line?
3) Eliminate combo valve "T" the front line and run rear from master to adj prop then to rear?
If using #3 would I need to do something about residual pressure check?
The more info the better. Thanks
I used the prop valve from a 79 Trans Am with 4wdb. One from a Seville should work also. I have 69 Camaro front discs and 77 Seville rears. Works great.
Tim
