Ok, Ill chime in..
A 39 amp draw might not be all the time if the fan is variable speed. And even if its not variable speed it still wont be on all the time. It should have a temp sensor that will shut it off when the temps are lowered.
So the 39 amp number is prolly when its running maxed out.
An 80 amp alt can easily supply an electrical system that was determined to need 150 amps at peak load.
Example? If you were to figure out what the peak load of your car's electrical system needed, thats with ALL the electrical devices ON at the same time and drawing max current then you have "peak" demand. You will never run into a sitch where you are using peak current. That would mean using the power windows (all the time), A/C on full, all the lighting on (interior and exterior), horn on, and the list goes on (power seats, EFI, windshield wipers, stereo... ETC...).
The peak load is a great place to start when determining what alt you need. Im not sure of how much it can be altered. Like if you determine your peak load is 150 amps and what size alt will be sufficient. But I do know that you dont need a 150 amp alt for a peak load of 150 amps.
And Im talking about a car with a "standard" stereo. Not one of the cars we see with four large amps and some massive current needs. Just a regular car with intermittent current draws along with some continuous current drawing parts (like an EFI system).
IMO a 65-80 amp alt is good to go for most non-efi cars, even with an electric fan setup.
Your fan wont be on all the time, it will cycle. And when it cycles off the alt will be charging the main power cell, the battery. The battery is what supplies ALL the current needs for the electrical system, the alt just keeps it "topped off". And batteries can handle some heavy current draw, yer starter is a biggy.
Peeps get caught up with the high current alts I think because of the media (mags and the stereo folks).
No need to go all critical with high amp alts for simple cars. GM does not so I think the drama with high current alts is kinda over played.
Umm? And voltage regulators? Someone talked about voltage regulators and how they monitor what the alt needs to put out.
A voltage regulator is just THAT, it controls the voltage. Your alt will produce a wide range of voltages depending on how fast it is spinning. They are designed to output at lease the lowest value of voltage for idling speeds. That would be fine if we idled the engine everywhere. But we dont. As the rpm of the alt rotor increases above idle it will also increase its voltage, thats just how alternators (AC) and generators (DC) work. More rotational speed means a higher voltage. Our cars need a certain voltage (13-14 or so). The voltage regulator WONT limit current from the alt to the batt. All it does is regulate the voltage.
Automobile voltage regulators are pretty primitive. They regulate the voltage to within volts. There are many voltage regulators that are tuned to milli and micro volts. But thats a diff story.
The car voltage regulator is in place to keep the alt from "cooking" the batt and to keep higher voltages off the system.
For example. You can have a 24 volt regulator on the end of your alt, it wont care, it will feed 24 volts to the batt and all the system when its running.
Problem? The batt will charge just fine. Even though its a 12 volt cell. But it WILL get damaged over time. Specially if its a "cheap" battery. It might short while charging and cook some plates. The 24 volts might be just enough to bridge the insulating gap internally. But with modern batts prolly not. You can put a 24vdc charge on them. But it will be a fast HOT cook for the batt. Its like putting a charger on start, 50 amps for the entire time. OHMs law.
Um, if you disconnect the alt from the system even though you were pumping in 24 volts the battery will still give you the 12vdc that you need. Its a 12 volt battery. You can charge a 12 vdc battery with 24 vdc and it will still provide 12 vdc. Thats just the way it is. The batt can handle more input voltage (to a point). But it will always supply the voltage (12-14) that its plates are configured for.
The car battery is more than a sink for the excess current that the alt provides. The battery is more important than folks think. Its a regulator in a way. It provides a constant voltage (more than the voltage regulator for the alt does). Its a constant voltage supply (due to the amount of plates) and a firm and stable DC that many electrical systems need. The alt dose NOT power your car, the battery does. JR
