Got out in the Nova yesterday, wanted to see what issue was and what soloutions available to firm up my front end, have been scraping the pan on big dips in the road.
Headed over to Port Moody Wheel Alignment. Who did my rear end install. Met 68SSGrandpa there with his green beast. This years plan is not a total front suspension upgrade, it is on the list for future years to come. So I advised Mike the owner of this. Mike assesed that due to my differnece in front/rear tire size and current rake of the car there were 2 issues. Shocks too soft and Bump Stops too short, need some stiffer shocks and some taller beefier Bump Stops. Left that with Mike to figure out which parts would be best. Quoted me 15 bucks per shock install and overall less than an hour labour with bump stop install. Was going to do at home but...re & re in an hour, with out me under the car in the hot garage toiling. pfft! Mike is another top notch guy to add to the list of stand up guys and shops. He will be getting my $ from the A arm and coil over upgrade in years to come.
68SSGrandpa and I headed out towards Pitt Meadows, brutal traffic and hot. Good test for my fans and cooling system. Stayed at 180. We took the new black sticky Abernathy connector
and then headed out to Neaves rd. We had some research to do on the cars.:devil:
On mine, to asses that my blue puff of smoke at starting of car is valve seals only. This was tested through robust bursts of acceleration and decelleration, while 68SSGrandpa followed noting exhaust results. All good, a wee bit of black smoke at launch, and wee bit of blue from passenger exhaust on hard decelleration, no other issues.
Next bit of research, assess if car is performing as per build and performance specs. 68SSGrandpa followed me from a very safe distance as I did a few 1-2 gear launches at 6000rpm shifts, and then a few 1-2-3 gear launches at 6000rpm shifts. 68SSGrandpa matching acceleration from safe distance to ensure accurate data collected on performance
We pulled over and reviewed the..."data". Results, 1st gear is a tire BBQ, 2nd spins a bit then hooks and pulls hard, 3rd is all business and is a rocket. Note: running my car up to 6000rpm in 3rd is a rare event and has my full attention and the pucker factor is very high
, but you have to stick to the research plan
. I was not watching the speedo, the road and shift light had my attention. 68SSGrandpa's "data" revealed the car went straight and true on launches and shifts, 3rd was clocking over 120 mph. Overall the car went like a "raped ape" a technically assigned 68SSGrandpa term.
Now "data" collection on 68SSGrandpa's. I followed and observed in same safe manner. On launches, much like mine a wee bit of black smoke at launch, and wee bit of blue from passenger exhaust on hard decelleration, no other issues.
1st gear is a tire BBQ, 2nd gear a tire BBQ. 3rd spins at start but then ......, well um. My car the "data" collection car at that time was unable to assess all of 3rd and 4th gear due to insufficent observation opportunity due to 68SSGrandpa's car producing a huge gap between the two of us. :devil:
68SSGrandpa's car fought through all 3 gears to maintain traction, lots of back end swimming. 68SSGrandpa has detailed "data" on current tire/traction challenges. Despite traction issues I also would use the technically assigned 68SSGrandpa term of went like a "raped ape" but times 2
, and screamed like "a banshee"
We concluded our tests and parted ways...smiling the smiles of two big dumb azz kids... I mean researchers.
Note: No golfers, boaters or other Neaves road users were harmed, endangered or mistreated in any way. Do not try this at home, as there is not enough road.... at your home.
Proffesor Kramer any additional "data"
Later I headed over to the A & W in Langley as I had never been to that crusie in. Ran into John (forget his handle), who was leaving and heading over to Tim Hortons. I followed and we hung out there for a while, not a big turn out but great to see some different cars. Was my first chance to spend some time with John. He is another avid car guy, quick to laugh and a real great guy. Thanks for the company John :thumbsup:
Back over the bridge and home. Fantastic day.
