Vintage Air made note of having oil already added.If you decide to do it yourself, don't forget the oil charge.
Don't use compressed air for this, use nitrogen if possible.Did you leak test the system? I would recommend it otherwise all your next work will be wasted it there is a leak.
I was going to do this myself and talked to a friend of mine that services A/C units and said he would come to my house,put a vaccuum on it,check for leaks and charge it for $35.00 with me supplying the Freon.Did you leak test the system? I would recommend it otherwise all your next work will be wasted it there is a leak.
That the right way to do it, and for 35 bucks cant beat that.I was going to do this myself and talked to a friend of mine that services A/C units and said he would come to my house,put a vaccuum on it,check for leaks and charge it for $35.00 with me supplying the Freon.
