The A/C in my 79 wasn't blowing out of the instrument panel vents. After going through the service manual several times, I found a broken vacuum line leading to the diverter door diaphragm which unfortunately is located behind the heater case & core assembly. So, since I have to remove it anyway, I'll be replacing the heater core too. I've searched previous posts and have a pretty good idea of what the job involves. I've replaced cores in other cars I've had but not one with A/C.
My questions are do I have to disconnect all the vacuum lines and the temperature cable to remove the case or is there room to maneuver with them connected? Do I remove the lines from the case end or from the control panel on the dash? Are there any electrical connections on the case that need to be disconnected, I don't think I saw any?
Thanks in advance for the help,
Mike
Mike
