1 - 2 of 2 Posts
I'm putting a 9" rearend back together. I didn't take it apart and I'm
not sure of the sequence to install the axles. Is it. Axle, backing plate,
axle flange,axle flange bolts? OR! Axle, axle flange and bolts, then backing
plate?
Thanks.
the retainer plate gets pressed on behind the bearing. Then slides through the backingplate into the housing. The studs come from the housing side so the nuts are seen through the access holes drilled in the axles.
Miles
1 - 2 of 2 Posts
