1 - 2 of 2 Posts
i posted the same thing over on yellowbullet in case it looks familiar.
i am changing my 5.14 gear to a 4.57 gear. the new gear is a motive gear # F890457. My pinion is a small bearing 28 spline.The gear set i bought still has a bearing on the pinion, witch is a daytona bearing, the guy i bought it from had six passes on it and kept the bearings with the gear set every gear change.
on motives site it list the pro gears diameter Big pinion 1.500" 35 spline
Small pinion 1.313" 28 spline
but on the performance gear sets (my new gear) they only list one pinion diameter 1.313" does this mean i can press a small bearing on to my new pinion and use my same bearing`support?
if you need any pics or more info let me know thanks.
Discussion Starter · #2 ·
got the answer i was looking for. i was told all pinions are the same except for 35 spline pro gears
thanks
1 - 2 of 2 Posts
