I got a 9 inch out of a 70 mustang its a direct bolt in except there are no alignment pins on top of the gm leafsprings do i need to weld some on or what
I don't know what to tell you about that. I run a ford 9", no problems at all with it. My leaf springs have the alignment pin. Look under the leaf spring, Do you have a hole there where the pin used to be? Do you have multi leafs or mono leaf?
You're not running ford leaf springs though. If you see the pin on the bottom, try and drive it on up towards the top. All that has to be sticking up above the spring is 3/8 to 1/2.
