well if you have your chevrolet rearend just measure from end to end and thats your measurement if your going with someone ( strange, moser, currie , etc... ) they might have the stock length already i would give them a call :yes:
stock is 60 inches, if you are buying a housing you want 55 inches because the axles stick out 2.5 on each side. if you have disc brakes in rear or are going to put disc on that will change your measurement. i bought the wilwood dynalites and i had to go a half inch on each side narrower. measure your rotor width to see or drum and subtract that from 55
I put a 9" from 68 Cougar in my 72. Works great with 8.5" rim with 4.5 backspacing and I have used 30x10x15 slick. Good luck!
