I'm putting a 9 inch ford in my 71 with mono springs.I will be using the ford spring perches without the rubber pads.The locator pin is on the underside of the spring.My lakewood traction bars have about a 1 inch hole and my pin is about a 1/2 inch diameter.Do I need to shrink the 1 inch hole down to a 1/2 inch so the rear will stay centered on the spring.Also what size diameter u-bolts the lower plate will fit a 1/2 inch bolt but could drill bigger if needed.It will have a 454 in front of it.I seen a picture of baddass70's sheared off locator pin on his mono spring so I want to find the best way to mount the rear to the spring.Any input will be helpful Thanks
