I don't have any photos of the bracing...but, basically I cut 4 short pieces of 1-inch tubing to fit between the back and the front of the center section just above and below the axle tubes on each side and welded them in - obviously, making sure they didn't interfere with the thirdmember, caps and ring gear. Then you can also weld in a plate vertically between the two braces on each side with a hole for the axle to pass through. This adds additional torsional bracing and acts as a baffle for gear oil control.
