1 - 9 of 9 Posts
anyone running an 8 inch rear wheel with 4 1/2 back spacing on a 68-72 multi spring
I am running an 8" with a 5.5 bs with multi's if that is any help. With a 4.5 you tires will stick out toward the outer lip too far, and won't fit without jacking the a$$ end way up.
Denis
i think stock is 4.5
i have 4.75 bsp with an 8" wide rim and 275/40's if i went to a 5" bsp i could run a 295 tire. i have lowered springs in the back and cut fender lips
If you have a 3rd gen I would say no. I have maybe 1/2 inch both sides w/275's.
its a 3rd gen, and have an 1/2 on the inside near the spring plus almost another 1/2on the outside..im running a 275 but with only a 40 series. makes a little bit of difference on the top of the side wall
1 - 9 of 9 Posts
