There's confusion because you aren't supposed to reuse the crush sleeve, however the GM official shop manual procedure doesn't require crush sleeve replacement if you mark the nut location so it the sleeve preload isn't changed.Thanks, Paul. I'm new at this 'end', but it seems the crush sleeve goes on the inside the center section with the pinion. Is there any way to stop the leak from the outside?
