1 - 3 of 3 Posts
What parts would you all recommend to upgrade the rear to handle 500-600 hp. Currently the rear is stock except for the girdle cover w/ tension bolts for the caps. thanks.
Len
c-clip eliminators or switching the housing ends to ford housing ends , better axles like moser , strange , superior , yukon , etc.... i would weld the axle tubes to the third member as well this should be more than enough to handle 500 to 600 hp . you may also want to look at a better pinion yoke too maybe a 1350 series type... oh and you can still use that girdle cover that will also help
1 - 3 of 3 Posts
