I have two issues, maybe related.
1. My ignition switch will not turn back to the lock position. It will turn forward and start the car, but will not turn back to the lock position. Also, I can pull the entire switch right out, even when the car is running. NOTE: When the switch is removed, the key has complete range of motion, lock position included. It's only when it's in the steering column does it misbehave.
2. Just yesterday, there is no power to the starter solenoid. I put a test light on it and it doesn't register anything. I drove the car just the other day and have been driving it regularly with no problems, even with issue number 1 above. When I turn the ignition switch to start the car, it seems as though everything else is fine; have full power to everything. When the key turns enough, if the radio is on, it shuts off as to be expected until the car starts. I can see the draw on the voltage meter gauge etc. Just zero power to the solenoid.
What to do?
What to do?
