I have a 74 Nova with a 350 engine and 350 transmission, I’m trying find the linkage assembly for the column shift. It was converted to a floor shifter and I want it back to a column shifter. Any pictures or help in the right direction would be very appreciated.
Generally, there will be a rod coming off the column down to a pivot bracket on the frame. From the pivot bracket there will be a rod going to the gear selector on the trans. Good used parts should not be difficult to find.
The assembly manual for the car will have drawings of the parts and how it went together. The factory shop manual will probably also have some references and data regarding adjustment. Sometimes you get lucky and there is a picture as well.
^ I agree. Unfortunately, I don't think you'll be able to find an assembly manual that covers '74 though (I have yet to see any listed for the '73+ Novas). But there is a good diagram of the '74 TH350 column shift linkage shown in the GM Parts & Illustrations catalog that can be viewed here --> http://www.gmpartswiki.com/getpage?pageid=87881
The '73 assembly manual is available now, it just has not spread out into the market yet. I believe Faxon is making them, they have them in their eBay store
The diagram you posted is about as good as you are going to get
Here's the setup off my 73 TH350. The end with the spring goes into the front subframe there should be a hole for it. I had to dig for these in my "probably will be selling bin."
Yep, I put in the same setup on the 71. Lokar from Summit I think. Pretty sweet (and much cleaner) setup. Will take some tweaks and adjustments, but check it out.
Faxon is awesome. If you are not familiar with them, they have been around forever and are always coming out with new product. I do not think these 4th & 5th gen manuals have been out for that long. They also buy and sell rare used literature. I try to keep an eye on their stuff as I am a literature junky.
I posted a want ad to get shifter linkage for a 1970 nova, but now I have more questions. The car has a 6cyd glide now with the bellcrank on the frame. And I bought linkage from a 1973 but it does not have the bellcrank and my frame does not have the hole in it for the cup piece. I was...
sorry to bring up an old thread but i have to do the same conversion, someone also made my at column shifterless up top. will this linkage work for any AT or just th350?
SeattleNova . . . . . this Is an Older Post . . . . . but , member 68bbnova , was last "posting , just 17
hours ago . So - - you may get some kind of answer .
However we may need too know just What You Mean by : . . . . . " someone also made my AT column shifterless up top " . . . . .
Would you have any pictures of that ........................... so , we could see just what you are talking about ?
also , in the link above : in ' Post # 16 - - by 68bbnova ' . . . shows some parts you may need .
at least check out those pictures ; and choose just which parts , could fit u'r car .
ps - - - - but you may have too address your "steering column issues" . . . . first .
I hope that makes some sinse .
. . . jim
Related Threads
Chevy Nova Forum
2.4M posts
56.7K members
Since 2004
